eliyahu100
I would like to Display A Survey Results using a Horizontal Bar 100% stacked chart in jmp
for example as presented in the following  image
How do I create this?
TIA
Re: I would like to Display A Survey Results using a Horizontal Bar 100% stacked chart in jmp
Depending on your data (you might have to stack it), you should be able to plot it easily using graph builder
eliyahu100
What is rhe recommended graph legend setting color for black and white publication?
