LearningJMP
I want to add formula to subtract 1st and 4th row, then 2nd and 5th row.. then 3rd and 6th row and so on..urgent please help!
:RESULT is the column where I want to subtract row 1 and row 4, then row 2 and row 5 and so on until all the rows finishes.
:TEST is currently an empty column where I want to store the results of :RESULT column
I tried the following script in the formula but it doesn't work? Not sure why?
:RESULT << Data Type( Numeric );
:TEST << Data Type( Numeric );
For( i = 1, i <= N Rows(), i++,
	Abs( :RESULT[i] - :RESULT[i + 3] )
LearningJMP
Re: I want to add formula to subtract 1st and 4th row, then 2nd and 5th row.. then 3rd and 6th row and so on..urgent please help!
Figured it out:
Had to update line:
to
:TEST[i]=Abs( :RESULT[i] - :RESULT[i + 3] )
Your formula should not contain a For() loop, unless you are running this not as a JMP formula, but rather as JSL in open code.  If you specify the code as being a formula for the column, JMP automatically loops through each row of the data, and applies the formula.  Thus, the For() loop is not required  Below is a little script that creates a new column and then adds a formula for the column.
dt << New Column( "The New Column",
	formula( If( :ATT1 == 0, 0, Abs( :RESULT - :RESULT[Row() + 3] ) ) )
If you have an empty column(for example, called "mytest") you can use a For Each Row() function to loop through the data table and calculate values
For Each Row(
	If( :ATT1 == 0,
		:mytest = 0,
		:mytest = Abs( :RESULT - :RESULT[Row() + 3] )
Finally, as you have indicated, you can use a For() loop to loop through the data table.  This code requires that one specifies the specific row to operate on
For( i=1, i<=N Rows(dt), i++,
	If( :ATT1[i] == 0,
		:mytest[i] = 0,
		:mytest[i] = Abs( :RESULT[i] - :RESULT[i + 3] )
Georg
In addition, to calculate with different rows, I recommend the function lag, that returns the value of a row relative to current row, and you do not need a loop.
Georg
Besides using Lag to calculate there is also specific row function for this: Dif ( JSL Syntax Reference > JSL Functions > Row Functions - Dif(col, n) ). Sometimes it might work better than using Lag.
