Steve: Thanks for the quick reply:
I have looked at the approximations, and I am not sure that they will work for my purposes. The Taylor series approximation:
is apparently slow to converge, and would need k = 30 in order to have three decimal point precision at the levels of x I would be dealing with. In addition, the wiki page states :
This formula can be used to compute
 with floating point operations for real
 between 0 and 2.5. For
, the result is inaccurate due to cancellation.
Which is rather ominous, seeing as I will be dealing with x values larger than 2.5. I understand that "floating point operations" just means that the computing device rounds off to a certain number of decimal points after each step of the calculation. Does JMP use floating point operations? Is there even an alternative? I suppose I could transform x in some way so that the values would fit in between 0 and 2.5.
There is another approximation that is divergent, which isn't great because it is divergent, but also because the error seems to be very large for small values of x (less than one), which is also within the range of x values I may use. If I need to use this approximation, then I will have to, but I would like to save it for last option.
The problem with calculating the Ei(X) and importing it into JMP, is that the argument of the exponential integral includes a parameter that I want to solve for using non-linear least squares. Therefore it needs to actually be encoded into JMP so that JMP can change the parameter in order to iteratively solve for it.
Is it really true that there is no INT() function in JMP?
Thanks for the help,
--SurfaceThought
