Jackie_
Hyperlinks to Table box rows
Is there a way to add hyperlinks to the table box rows?
dt = Open( "$SAMPLE_DATA/Cities.jmp", invisible );
New Window( "", dtb = Data Table Box( dt ) );
:Latitude << Set Property(
	"Event Handler",
	Event Handler(
		Click(JSL Quote(
Function( {thisTable, thisColumn, iRow},
	Web(
		"https://www.google.com/maps/@" || Char( thisTable:latitude[irow] ) || "," ||
		Char( thisTable:longitude[irow] ) || ",12z"
			Tip( JSL Quote(Function( {thisTable, thisColumn, iRow}, "Open " || Char ( thisTable:iMVInumber[ iRow ] )  || " in your browswer."; ); ) ),
			Color( JSL Quote( Function( {thisTable, thisColumn, iRow}, 5;); ) )
dtb << set selectable rows( 1 );
Re: Hyperlinks to Table box rows
I think you might have to use Col Box with Button Boxes
New Window("Example",
	Table Box(
		String Col Box("strings", {"x", "y", "z"}),
		Col Box(
			"boxes",
			Button Box("JMP", Web("www.jmp.com"), << Underline Style(1)),
			Button Box("Google", Web("www.google.com"), << Underline Style(1)),
Jackie_
Thanks @jthi.
I am unable to get the row values in the web link. Can you share an example to get the row values in the web() function?
You wish to know how to build Table Box with hyperlinks using same example as in your first post? Should the table box contain all the columns from data table or only the coordinates / name of the city?
