How to write .jmp files with JMP python
Hi,   I am using JMP19.1.1
I see examples of how to use JMP or JSL to open files, add jsl scripts for plotting and then run them.
Are there examples to use JMP Python to open csv files and write .jmp files with charts in them?   What do people do?
Adrian
10 REPLIES 10
Re: How to write .jmp files with JMP python
sqlite3 has a max # of column set at 64K.  If you're under that limit you're probably good to go, but I would also check size of the resulting db.  Might not be that much smaller if your files are primarily text.  Numerics should take up much less space than CSV.
