rverma
How to walk a directory with many sub-folders to fetch specific files?
I have a folder/directory with many sub folders. In each of the subfolder there are bunch of csv files. Each csv file has a unique ID in the filename. My question is that if I have a list of IDs then how can I traverse the directory to fetch those specific csv files and concatenate them in a jmp table? Is there a way to do it with a script (JSL)? I will appreciate any guidance. CSV file name is similar to "Y123456_File_27A7Z123456.csv". String after File_ is the unique id.
Thanks
Re: How to walk a directory with many sub-folders to fetch specific files?
The Files in Directory() function has a recursive option that returns the full path to each of the files found.
See
     Help=>Scripting Index=>Files in Directory
See
rverma
Thank you. I was able to achieve what I wanted by saving all filenames in the directory into a list.
filelist=Files In Directory( path1, recursive);
Then I created another list of the unique IDs.
unitIDlist = {"AA", "AB","AC"};
Finally I used Nested For loop to find the files that contains unique IDs in the filename and open and concatenate them to the first file.
Craige_Hales
also take a look at multiple file import. It may be exactly what you need.
Craige
