shampton82
How to use what is returned from "get Scriptable Objects"
Hello everyone,
I was wondering how I can use what is returned from Getting a Scriptable object.
 For example, I have this code that I use with the distribution platform
biv={};
Biv1={};
Biv2={};
Biv3={};
test=0;
Biv1 = Current Report()[OutlineBox(1)] << Get Scriptable Object;
Biv2 = Current Report()[OutlineBox(2)] << Get Scriptable Object;
Biv3 = Current Report()[OutlineBox(3)] << Get Scriptable Object;
if(biv3=={Distribution[]},
		Biv = Current Report()[OutlineBox(3)] << Get Scriptable Object;
		test=3;
	biv2=={Distribution[]},
		Biv = Current Report()[OutlineBox(2)] << Get Scriptable Object;
		test=2;
	biv1=={Distribution[]},
		Biv = Current Report()[OutlineBox(1)] << Get Scriptable Object;
		test=1;
The problem is that my If statement is not working as none of the Biv1-3 are recognizing the scripital object return value.
I'm using this to identify if there is a local data filter or column switcher and thus return the right outline box.
if there is no LDF or CS then i use outline box 1, if there is either a LDF or CS I use outline box 2, if there is both a LDF and a CS I use outline box 3.
thanks for any ideas
Steve
Re: How to use what is returned from "get Scriptable Objects"
Maybe you could try changing those to characters? Not sure how robust this would be but could work just fine:
if(char(biv3) == "Distribution[]",
pauldeen
If all you are after is the right outline box, then why not use the name of the outline box in your code?
SpecifcBox = Report(Biv)[OutlineBox("Name of the box you are after")]
Maybe solution from here can help Check Display box existence by JSL
shampton82
That was really good to read and I'm sure I'll use it in a different script but the help I need is not knowing if the a Outline box exists but which one is the Distribution[] one.
pauldeen
