ajp
ajp
How to use multiple selections from a List Box
Hi All,
I am attempting to create multiple control charts from selections made using a list box.  I can select multiple items, but I am not sure how to create a chart for each item chosen.
ms
Super User (Alumni) ms
Re: How to use multiple selections from a List Box
The  <<get selected message will return a list of the selected items of a List Box or a Col List Box. Then loop over the list to create the charts.
An example:
dt = Open( "$SAMPLE_DATA/Quality Control/Coating.jmp" );
New Window( "select columns",
    <<modal,
    cl = Col List Box( all, cols = cl << get selected )
nw = New Window( "test" );
For( i = 1, i <= N Items( cols ), i++,
    nw << append(
        dt << Control Chart Builder(
            Variables( Subgroup( :Sample ), Y( cols[i] ) ),
            Chart(
                Position( 1 ),
                Points( Statistic( "Average" ) ),
                Limits( Sigma( "Range" ) ),
                Connecting Line( 1 )
ms
An example:
    <<modal,
    nw << append(
            Chart(
                Position( 1 ),
ajp
ajp
Thanks!  Much appreciated!
