BookmarkSubscribeRSS Feed
nkelleh
Community Trekker
Dec 19, 2012
How to use '<< Select Where' or '<< Get Rows Where' on a list of columns names or references?
Basically, I have script where I'm trying to return the row numbers of certain columns that contain a specific value. In my example, I have several columns where the value can either be a 1 or a 0. I'm trying to get the row numbers for any row that contains a zero regardless of which column its in. I can do this easily enough for one column using the following syntax:
selectedRows = datatable << Get Rows Where( As Column(colNameStr) == 0 );
However, when I want to do this for a number of columns, say in a list of column names or references, I'm stumped. I feel like this should be catered for, but I can't figure out if its possible or what the correct syntax is. For example
selectedRows = datatable << Get Rows Where( FOR EACH COLUMN IN LIST == 0 );
Any help on this matter would be greatly appreciated. The reason why I want it to work with a list is that I want it to work for any number of columns or column names. I'm using JMP11.
Thanks.
vince_faller
Mar 17, 2015
Solution
Re: How to use '<< Select Where' or '<< Get Rows Where' on a list of columns names or references?
list = {:A, :B, :C};
dt << Select Where(ANY(list));
This only works as is because you have boolean values in your columns.
vince_faller
Mar 17, 2015
Solution
nkelleh
Community Trekker
Dec 19, 2012
Thanks very much! I knew there was some way to do it. Out of curiosity, is there any way to do it for non-boolean values?
Thanks again!
vince_faller
Mar 17, 2015
With the list?  Can't think of anything off hand.
You could do
ANY(:A == "donkey", :B <=14, :C), C being a boolean still
