ENTHU
How to use column name in the formula ?
I have a table as below.I need to find the sum of (TA008+SA2900 to SA2950+SA3400 to SA3500+TA99) for every item.How can have jsl do this?
ItemSA0100SA0801SA0804SA0817SA0818SA0871SA0874SA2930SA2950SA2982SA2983SA2984SA3403SA3404SA3422SA3423SA3424SA3452SA3474SA3476SA3477SA3491SA3534SA9706SA9787SA9798SA9901SA9908TA001TA008TA029TA034TA035TA088TA097TA099
8A63012 2                        7122     7
8A6311814  1                     11186     11
8A63212 1 31                     21125     21
A63381 1 22                  1  13815    113
A629249  1 2                  1  332493    133
A626380   23                     133805     13
A60011 1   1                1   3112    13
Georg
Re: How to use column name in the formula ?
Here's just another way how to deal with columns to make a formula:
// expression way
cdt=current data table();
sum_lst2 = {};
col_lst2 = cdt << get column names( Numeric );
For( i = 1, i <= N Items( col_lst2 ), i++,
	colname = Column( col_lst2[i] ) << get name;
	If( Contains( {"TA008", "TA099"}, colname ) | (colname >= "SA2900" & colname <= "SA2950") | (colname >= "SA3400" & colname <= "SA3550"),
		Insert Into( sum_lst2, col_lst2[i] )
Eval( Eval Expr( cdt << New Column( "Sums_expr", formula( Sum( Expr( sum_lst2 ) ) ) ) ) );
Georg
dt = Current Data Table();
dt << New Column( "Sums",
	formula(
		Sum(
			:SA2930,
			:SA2950,
			:SA3403,
			:SA3404,
			:SA3422,
			:SA3423,
			:SA3424,
			:SA3452,
			:SA3474,
			:SA3476,
			:SA3477,
			:SA3491,
			:TA008,
			:TA099
The above will add a new column to your data table with the sum being added from the required columns into the new column
ENTHU
The data set is dynamic.I could have columns with names SA3400 to SA3450 and SA2900 to SA2950.I would have to mention over 100 column names if I followed this approach.Trying to fins a way to simplify.
Ah......that requirement was not stated in the original question.
However, the code to do what you want is repetitive, but not difficult.
names default to here(1);
colNames = dt << get column names(string);
sumList = "";
if(contains(colNames,"TA008"),
	sumList = ":TA008";
For(i=2900, i<=2950, i++,
	If( contains(colNames,"SA" || char(i)),
		if( sumList != "", sumList = sumList || ",");
		sumList = sumList || ":SA" || char(i);
For(i=3400, i<=3500, i++,
if(contains(colNames,"TA099"),
	sumList = sumList || ":TA099";
Eval(
	Parse(
		"dt << new column(\!"Sums\!",formula(sum( " || sumList ||
Georg
// expression way
sum_lst2 = {};
Georg
