ChrisMuenzer
How to use a variable in JSL to set the levels of a DOE factor?
I'm trying to add a factor to a DOE using a variable instead of hard coding the levels. The end goal is to provide the user with a simple interface set the levels for one of the factors.
The following code doesn't work and the factor just ends up with L1 and L2 as levels.
levels = List(1,2,3);
d = DOE(
	Custom Design,
	Add factor(Discrete Numeric, levels)
d << Make Design;
d << Make Table;
Re: How to use a variable in JSL to set the levels of a DOE factor?
Here is an example I created interactively with a Continous factor and a Discrete Numeric factor.
levels = {1, 2, 3};
obj = DOE(
	Custom Design,
	{Add Response( Maximize, "Y", ., ., . ),
	Add Factor( Continuous, -1, 1, "X1", 0 )}
Eval(
	Substitute(
		Expr( obj << Add Factor( Discrete Numeric, LLL, "X2", 0 ) ),
		Expr( LLL ),
		levels
GL970879
Hello~
According to  the example that you created, how to use variables for the "levels", and then add a "Categorical" factor to obj?
For example:
value = "11";
value = "21";
value = "31";
levels = {value1, value2, value3};
