antoinesofradir
How to use a value selected in a list ?
Hi, i selected a value in a list thanks to a window, this value is keep in a variable.
i would like now to select the lines in my data table which correspond to this value, how can i do ?
here my script :
value = {"1","2","3","4"};
New Window( "window",
Outline Box( "example",
  H List Box( Text Box( "select value" ), listvalues= list Box(value, nlines(4))),
  Button Box( "OK",
    value = (listvalues << Get selected);
    nw << Close Window;)
dt << Select Where(variable== value);
thanks for your help !
ms
Super User (Alumni) ms
Re: How to use a value selected in a list ?
Value will be a List of strings. Char must be used if variable is numeric.
If only one item is to be selected selected, this should work:
dt << Select Where(contains(char(variable)==value[1] ));
The below works also if several items are selected:
dt << Select Where(contains(value, char(variable) ));
ms
