ALopez
How to use a list to select rows with an specific value
Hi I am trying to use a list of Names that populate a column to select the matching rows of another column (in another Table) in order to subset the table and generate several different subsets.
Getting the Names/Values from the first column is no problem but I cannot find the correct syntax for the loop.
dt4 = Current Data Table();
uniqueVals = {"2021_file1_T1", "2021_file1_T2"};
tableList= {};
For(i=1, i< N Items(uniqueVals), i++,
dt4 << select where( As Column("Type") == [i] ) );
dt4 << Select Columns (all);
newdt[i] = dt4 << Subset( Selected columns );
Insert Into(tableList, Data Table(newdt[i]));
dt4 << Clear Column Selection();
dt4 << Clear Select();
);// end of For
I think that my basic logic is OK  since this code works very well
dt4 << select where( As Column("Type") =="2021_file1_T2");
dt4 << Select Columns(all);
dt4 << Subset (Selected columns);
But I cannot figure out how to pass [i] to the "Select Where".  Attached is a simplified test table.
I will appreciate any hints/ solution/suggestions.
Re: How to use a list to select rows with an specific value
You were pretty close in getting done what you want.  Below is my rework of your code.  Please note that your tableList list is redundant with the newdt list that you are referencing.
//tableList = {};
newdt = {};
For( i = 1, i <= N Items( uniqueVals ), i++,
	dt4 << select where( As Column( "Type" ) == uniqueVals[i] );
	dt4 << Select Columns( all );
	//Insert Into( tableList, Data Table( newdt[i] ) );
//tableList = {};
newdt = {};
ALopez
Hi @txnelson, So close yet so far.... Thank you very much for your help.
