I am sorry - I thought it was a very simple task which could be solved without examples ;)
Constructed data table (Real ones have much more columns and rows):
Corresponding simplified graphs - one for each parameter:
On the left is the Y axis label. It is automatically called "Entered value" corresponding to the header of the column containing the values. I would like the Y axis to not be called "Entered value", but use the text from the "Unit" column; Here it would be "Number" for "Particles" and "%" for "Purity".
How can I ask Graph Builder to get the value from the "Unit" column and apply as the Y axis label for each graph?
Thanks in advance :)
