mystylelife19
How to use Set Function {self}
I explore all the question and answer inside this community and still not getting my answer to use this script. Can you help me, please?
I have data table with all the parameter (column) and data (row). My question is how to use Radio Box with the set function {self} to display all the data that i chosen one parameter on Radio Box to see at Bivariate (Fit Y by X).
I don't want to click OK to see the output on Bivariate, just click parameter on radio box.
I attach with example data table below,
Here my full script but still my radio box won't function using set function {self}
//Get the current data Table
dt = Current Data Table();
// Get the all column names from the data table
columnNames = dt << Get Column Names("String");
cl = New Window("Column Selection", <<Modal,
		  Panel Box("Make a selection",
			  allcolumn = RadioBox(columnNames,
			    <<Set Function(
			    Function({self},
						match(self << Get Selected,
							allcolumn, columnNames << Set //i don't know on how to set funtion {self} to all parameter
// If cancel or X was clicked, stop the script
If( cl == {Button( -1 )}, Stop() );
Bivariate(
	Y( :Y ),
	X( :X ),
	By( :WAFER_ID, :SITE_NO ) );
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Row Legend(
				allcolumn, //this one is referring to the radio box parameter for what i choosing
				Color( 1 ),
				Color Theme( "Spectral"(1) ),
				Marker( 0 ),
				Marker Theme( "" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
Craige_Hales
Re: How to use Set Function {self}
dt = Open( "$sample_data/big class.jmp" );
columnNames = dt << Get Column Names( "String" );
cl = New Window( "Column Selection",
//	<<modal, // optional, probably not what you want
	H List Box(
		Panel Box( "Make a selection",
			allcolumn = Radio Box(
				columnNames,
				<<Set Function(
					Function( {self},
						col = self << get selected;
						Try( (reportHolder << child) << delete ); // remove old content
						reportholder << append( dt << Distribution( Nominal Distribution( Column( Eval( col ) ) ) ) );
		reportHolder = Border Box()
Craige
Craige_Hales
GUI design rules don't usually run code when a radio button is picked. You can break the rule, but users may not like it. This example will let you choose either path
	<<Modal,
	<<Return Result, // this is the magic part you are missing
			columnNames,
			<<Set Function( // I don't think you want this at all,
				Function( {self}, // but here's an example.
					Match( self << Get Selected,
						"age", print("you picked age"),
						"height", print("you picked height"),
						"weight", print("you picked weight"),
						print("you picked this:",self<<get selected)
// this is what I think you want...
show(columnNames[cl["allcolumn"]]);
<<return result is my preferred way to get the results from the dialog, after OK, and then process them.
The code that runs when a radio button is clicked usually disables/enables another part of the dialog; you might, for example, change available options when a numeric vs character variable is chosen in the radio list.
Craige
mystylelife19
Thankyou for reply my question,
Sorry i still don't understand...
Actually i want to have the output wafer map that shows based on my click Radio Box. Is it possible to do it?
Because i don't want to click OK everytime i choose the parameter on Radio Box. I want to make the Radio Box stay appear on my screen everytime i click OK or just using self function to see the output on wafer map. I tried to have all the column names with self function but still doesn't work.
How to write the self function with all the parameter i have?
Also how to make the Bivar Plot, Row Legend based on radio box i choose?
For example i want based on my images:
1. Red one is parameter on radio box i choose that make Row Legend on Bivor Plot
2. Blue one is the output i want to see based on row legend i picked on radio box
Craige_Hales
	H List Box(
				columnNames,
				<<Set Function(
					Function( {self},
Craige
mystylelife19
Thankyou, it works!
I have one small problem my script everytime i click on radio box 5 times, it will open 5 display windows. How to make everytime i click the radio box it will change the current display windows not the open new one.
Can you help me to check my script...
Here below i attach the picture of my problem
	H List Box(
				columnNames,
				<<Set Function(
					Function( {self},
						Bivariate(
							Y( :Y ),
							X( :X ),
							By( :WAFER_ID, ),
								Dispatch(
									"Bivar Plot",
									FrameBox,
									{Row Legend(
										Eval( col ),
										Color( 1 ),
										Marker( 0 ),
										Marker Theme( "" ),
										Reverse Scale( 0 ),
										Excluded Rows( 0 )
Craige_Hales
This was harder to write than it looks, but turned out simpler than I expected.
anchorPoint = Empty(); // no previous window remembered yet
// the report to generate with col which depends on col being global.
// used below, either as Report(...) which makes a new window,
// or <<apend(...) which append to an existing box.
// write the expression once and use it in several places below...
makereport = Expr(
	H List Box(
				columnNames,
				<<Set Function(
					Function( {self},
						If( Is Empty( anchorPoint ),
							newReport = Report( makereport );
							anchorPoint = newReport << TopParent;
						, // else try to reuse the window if it still exists
							(anchorPoint << child) << delete; // remove old content
							anchorPoint << append( makereport ); // add new content
// force the item 1 script to run without running the item 2 script
allcolumn << set( 2, runscript( 0 ) );
allcolumn << set( 1, runscript( 1 ) );
Simpler than expected because anchorPoint becomes empty when the window is closed. I was writing several try() blocks to handle closed windows...but didn't need them. Cool! The last two lines at the end are the only way I could find to run the script for the current selection to pre-open a window.
Anyone reading along: this design might or might not violate a GUI design principle that radio buttons should select something but not perform an action. If you believe the radio button in this application is selecting a variable and showing a visual to help with the selection process, great! But if you think you are using the radio button to perform the analysis, you might be frustrating your users!
Craige
