How to use JSL to achieve the specified character conversion to sha256 encryption?Thanks!
Created:
May 5, 2023 05:26 AM
| Last Modified: Jun 9, 2023 9:09 AM(2460 views)
For example, an sha site that calls a specified character with JSL converts it to sha256 encryption and can store the result of this conversion in a JSL variable.
The article 7 things to know about Twitter is pretty old, and I'd recommend using a python package to access Twitter at this point, but...
There is some code with the article that computes a SHA1 hash using the windows program certutil. It appears certutil will also calculate a sha256 as well. Call it with RunProgram. On a mac there is a similar approach with openssl.
