  • Learn some foundational elements of JMP Scripting Language (JSL) and how to extend point & click automation into repeatable, shareable routines. Register. June 26, 2 p.m. US Eastern Time.
lukasz
How to update table after sorting?
Hello Everybody,
I have an issue regarding sorting of a table. I wanted to sort table by Date (located in Date1 column) and I am doing that after certain condition is met. However, it does not sort and replace the table EL_summary after sorting. Is there any refreshing necessary? I put also some delay, I thought one need to wait some time. When I am not using replace table(1), the new Table under different name is created and opened (what I don't want) and again data in this table is not sorted. After that, however, data in EL_summary seems to be updated and sorted. I would appreciate for pointing what I am missing. Best regards
Current Data Table( EL_summary );
if( N rows(EL_summary) > 0, EL_summary << sort(by(:name("Date1")), Order( Ascending ), replace table(1)));
wait(1);
12 REPLIES 12
Re: How to update table after sorting?
One option:
  1. Use << Get Window List to get references to all open windows (you can limit this to Type("Reports") if you want to)
  2. Loop over that list and check if there are any which are dependent on the data table being sorted (you should be able to use either the name of the report window OR << Get Data table. If the report belongs to the data table, add it to list
  3. If there are any items in the list, show the message to user
hogi
Level XIII
Works great thanks :)
closeMyReports = Function( {dt},
	{default local},
	AllmyReports = {};
	myReports = Get Window List( Type( "Reports" ) );
	For Each( {rep}, myReports,
		Try(
			myList = (rep << Xpath( "//OutlineBox" )) << get scriptable Object();
			myDTs = Transform Each( {scriptableObject}, myList, If( Is Empty( scriptableObject ), ., scriptableObject << Get Data Table() ) );
			If( Contains( myDTs, dt ),
				Insert Into( AllmyReports, rep )
	If( N Items( AllmyReports ) > 0,
		If(
			ex = New Window( "",
				<<Type( "Modal Dialog" ),
				<<Return Result,
				V List Box( Text Box( "open reports detected.\!nOK to close them?" ), H List Box( Button Box( "OK" ), Button Box( "Cancel" ) ) )
			ex["button"] == 1;
			AllmyReports << close window(),
			Stop()
dt = current data table();
closeMyReports(dt)
edit: now the script also checks for more complicated reports with many data tables.
hogi
Level XIII
Next step: is there a command:
dt << get linked subsets()
