Titanescu
How to update "fit x by y" analysis with multiple y data
I'm new in usin JMP.
I've performed "fit x by y" analysis with twenty "y "data.
Then, I've changed values for some data in the table. Thus, results of "fit x by y" analysis are exact anymore.
I'm now trying to update "fit x by y" analysis for all Y data using few click (a method quicker than clicking on the red Arrow of Y data analysis on by one).
Is it possible?
thank you very much for your help,
cwillden
Re: How to update "fit x by y" analysis with multiple y data
I think what you're saying is you have 20 "Y" variables (i.e. columns), not 20 rows of data, right?  And your problem is you have to do everything 20 times to apply updated data?  There is a general trick to applying changes to all instances of reports within a report window when you are using something like a "By" variable or have multiple responses.  That is to hold Ctrl when you click through the red-arrow menu.  In your case, do what Jim suggested while holding the Ctrl key down.
In addition, if you save the script to the data table, you can you always reproduce the entire analysis with updated data just by running the script again.
-- Cameron Willden
Simply select the Automatic Recalc from the Red Triangle, and your charts will automatically be updated when the data table changes
In JMP 13 & 14 it is
     Redo==>Automatic Recalc
cwillden
-- Cameron Willden
Titanescu
Dear Cameron,
Thank you, this is the solution!
With my best regards,
Alain
