Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMPĀ® Marketplace
D_T_M
How to transfer graph data into powerpoint ?
I usually have to manually transfer graph data ( ex: shown below), by copying three plots at once and transferring them into a new slide in powerpoint manually. I usually have about 40-50 of such plots and it is time consuming to transfer manually each time. Is it possible to automate this in JSL and send pair of 3 plots into a new slide?
(Apologize for blacking out column names).
Re: How to transfer graph data into powerpoint ?
There are previous answers to this question, here is one of them
Two graphs to single PowerPoint slide
