janeg
How to tell a window has not been closed?
Can someone tell me if there is an easier way to tell if a window is still open?  I have a case where a task is being done.  Once it is done, the window is closed.  However, the user can close the window before then.
I can't find the jsl command that equals   Is Valid
J
window_ptr = New Window( "hi", Text Box( "abcd" ) );
window_title = (window_ptr << Get Window Title());
Wait( 5 );
windows = Window();
window_open = 1;
For( i = 1, i <= N Items( windows ), i++,
   tmp_title = (windows << get window title);
   If( window_title == tmp_title,
      window_open = 0
If( window_open == 1,
   Print( " window is closed." ),
   Print( " window is open." )
ms
Super User (Alumni) ms
Re: How to tell a window has not been closed?
Here is one way to avoid the loop:
if(window(window_title)=={},  Print( " window is closed." ),
   Print( " window is open." ));
ms
janeg
Awesome!  That does exactly what I wanted.  Thank you!
pmroz
I just found another way to do the same thing.  Use is empty() on the window variable.  If it's true, then the window is not open.  If it's false, then it is open.
Wait( 5 );
window_open = !Is Empty( window_ptr );
If( window_open,
    Print( " window is open." ),
