helalmob
How to sum scores across multiple columns with condition?
I have a data set that includes 1600 subjects and more than 100 variables/questions. I need to calculate the total score across the 33 question items (Q1 thru Q33) ranging from 0 to 4 for each subject where the score of each question >= 2 excluding 0 and 1. Any help/suggestions/directions are greatly appreciated.
Thank you
Hella
PS. I am using JMP Pro 16.2
Re: How to sum scores across multiple columns with condition?
Here is one way to calculate the values.  It is an efficient way to calculate the final score.
dt = current data table();
dt<<new column("theRow",set each value(row()));
dtStack = dt << Stack(invisible,
	columns(
		:Q1, :Q2, :Q3, :Q4, :Q5, :Q6, :Q7, :Q8, :Q9, :Q10, :Q11, :Q12, :Q13, :Q14,
		:Q15, :Q16, :Q17, :Q18, :Q19, :Q20, :Q21, :Q22, :Q23, :Q24, :Q25, :Q26, :Q27,
		:Q28, :Q29, :Q30, :Q31, :Q32, :Q33
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" ),
	"Non-stacked columns"n( Keep( :theRow ) )
dtStack << select where( :Data <2 );
dtStack << delete rows;
dtSum = dtStack << Summary(invisible,
	Group( :theRow ),
	Sum( :Data ),
	Freq( "None" ),
	Weight( "None" ),
	statistics column name format( "column" ),
	Link to Original data Table(0)
close( dtStack, nosave );
dtSum << delete columns("N Rows");
dtSum:Data << Set Name("Score");
dt << Update(
	With( dtSum ),
	Match Columns( :theRow = :theRow )
close( dtSum, nosave );
dt << delete columns("theRow");
	columns(
	Group( :theRow ),
	Sum( :Data ),
	Freq( "None" ),
	Weight( "None" ),
dt << Update(
	With( dtSum ),
helalmob
Jim,
Thank you. Worked like a charm!
Helal
