miguello
How to store Import Settings of Open() function in a separate expression
I need to open CSV files with various settings.
One of the examples is below:
dt = Open(
	filePath,
	Import Settings(
		End Of Line( CRLF, CR, LF ),
		End Of Field( Comma, CSV( 0 ) ),
		Strip Quotes( 1 ),
		Use Regional Settings( 0 ),
		Scan Whole File( 1 ),
		CompressNumericColumns( 0 ),
		CompressAllowListCheck( 0 ),
		Labels( 1 ),
		Column Names Start( 18 ),
		Data Starts( 19 ),
		Lines To Read( "All" ),
		Year Rule( "20xx" )
I would like to store these settings that come inside Import Settings() construct as a separate expression and then use it when opening a file.
Something like this (but it doesn't work this way obviously):
settings1 = Expr(
Import Settings(
<my import settings here>
settings2 = Expr(
Import Settings(
<some other import settings here>
if(condition, importSettings = settings1, importSettings = settings2)
dt = Open(
filePath,
Eval(importSettings)
Re: How to store Import Settings of Open() function in a separate expression
One option could be wrapping them like this:
settings1 = Expr(
	dt = Open(
		filePath,
		Import Settings(
			End Of Line(CRLF, CR, LF),
			End Of Field(Comma, CSV(0)),
			Strip Quotes(1),
			Use Apostrophe as Quotation Mark(0),
			Use Regional Settings(0),
			Scan Whole File(1),
			Treat empty columns as numeric(0),
			CompressNumericColumns(0),
			CompressCharacterColumns(0),
			CompressAllowListCheck(0),
			Labels(1),
			Column Names Start(1),
			Data Starts(2),
			Lines To Read("All"),
			Year Rule("20xx")
settings2 = Expr(
	dt = Open(
		filePath,
		Import Settings(
			Strip Quotes(1),
			Scan Whole File(1),
			Labels(1),
			Column Names Start(5),
			Data Starts(6),
			Year Rule("20xx")
filePath = "somefilehere";
settings1;
settings2;
settings1 = Expr(
	dt = Open(
		filePath,
		Import Settings(
			Strip Quotes(1),
			Scan Whole File(1),
			Labels(1),
			Data Starts(2),
			Year Rule("20xx")
settings2 = Expr(
	dt = Open(
		filePath,
		Import Settings(
			Strip Quotes(1),
			Scan Whole File(1),
			Labels(1),
			Data Starts(6),
			Year Rule("20xx")
settings1;
settings2;
miguello
I guess I will have to spell out Open() function multiple times then. Or try to use Eval Insert()
You might be able to do something with techniques mentioned here Can you construct this without writing expression as a string?
open_expr = Expr(Open(filePath));
settings1 = Expr(
	Import Settings(
		Strip Quotes(1),
		Scan Whole File(1),
		Labels(1),
		Data Starts(2),
		Year Rule("20xx")
Insert Into(open_expr, NameExpr(settings1));
Name Expr(open_expr);
