abdul_saqib
How to stop JMP open file which was opened in a previous session
Hi, in JMP 13.2.1, I mistakenly said 'yes' to a message which has allowed JMP to open a file which I had opened in a previous session. Is there a way to stop JMP open the file on its own every time I start the software, please. Thanks
Re: How to stop JMP open file which was opened in a previous session
You should be able to clear this by:
1. Closing the data table after it has been opened and then exiting JMP.  When you restart JMP it should not be there.
2. Go to File==>Preferences, the General Tab, and change the settings for Save the Session, to never
3. Go the the saved JMP file, and rename it, using the File Explorer window
abdul_saqib
Thanks Nelson
