bpp0920200
How to specify a number array
Hello Guys,
I want to specify a number array from 1 to 100.
Right now I am doing it in the following way.
sel[1] = {"1", "2", "3", "4", .....continued upto "100"};
But this method is very cumbersome as I have to type in all numbers up to 100. Is there any shorter way in which I can tell JMP that I mean all numbers from 1 to 100.
Thanks
pmroz
Re: How to specify a number array
To get a matrix of 100 values going from 1 to 100:
a_matrix = 1::100;
To convert this to a list:
a_list = as list(a_matrix)[1];
ms
Super User (Alumni) ms
Your example shows a list of numbers within quotation marks, i.e. text-formatted numbers. If that's what you need, this formula would do it:
Local({i = 0}, Repeat({i++; Char(i)}, 100));
