Jingook
How to solve the error of window tap? Windows 11 install problem?
Hello. Everybody!
I have a big trouble using the Jump.
After my pc upgrade to Windows 11, then find error at Jump Pro. Thus, I downgraded with Windows 10.
After install Jump Pro, I can not add the item in the left bot to the right box.
It cannot show the action. Also, it does not show the click for a second choice of the item in the left box.
Pls, give me the solution from this problem.
Thanks in advace.
Jingook
Jingook
Re: How to solve the error of window tap? Windows 11 install problem?
Hello, Craige_Hales
I much appreciate to your comments.
The problem solved it.
Have a great day!
Jingook
Jingook
Hello, Craige_Hales
Have a great day!
Jingook
