JMPer1
How to snap the crosshairs on the curve?
While crosshair tool is useful to read the approximate values around the curves it would be good to snap on a smoother-ed curve that is closest to the crosshair. Is that possible?
SDF1
Re: How to snap the crosshairs on the curve?
Hi @JMPer1 ,
  I do not believe this is an option -- I have not seen any way to do this at least. It's a great idea and one that could be very useful to a broad range of users.
  You might consider adding it to the JMP Wishlist here.
DS
SDF1
Hi @JMPer1 ,
DS
