Learner_JMP
New Member
How to show multiple summary statistics in a graph for single set of points
I'm building a graph using a scattered plot.
My points are based on the "mean" statistics.
I'd like to add labels of "mean" and "N" statistics to the same points.
Since the scale is very different between "mean" and "N", adding second set of same points to the graph hides all the differences of "mean" statistics.
How can I show both statistics to the single set of "mean" points?
I'm hoping I don't have to use JSL script if there's a simple way to do this.
If I have to script, I tried this but "N" labels never show up while "mean" labels show up as expected.
Can anybody help?
Thank you so much!
Graph Builder(
	Variables( X( :p ), Y( :a ) ),
	Elements(
		Points(
			X,
			Y,
			Legend( 5 ),
			Summary Statistic( "Mean" ),
			Marker Size( 8 ),
			Marker Color( "Medium Blue" ),
			Label( "Label by Value" ),
	Elements(
		Text(
			X,
			Y,
			Summary Statistic( "N" ),
			Label( "Name and Value" ),
			Jitter( 0 ),
			Label Justification( "Right" ),
			Set Font Style( "Bold" ),
			Set Font Size( 12 )
	SendToReport( Dispatch( {}, "Graph Builder", OutlineBox, {Set Title( "Mean Points with N Labels" )} ) )
txnelson edit: moved code to JSL display box
Level XIII
Re: How to show multiple summary statistics in a graph for single set of points
How about Caption / Graph per factor?
Names Default to Here(1);
Graph Builder(
	Size( 643, 335 ),
	Graph Spacing( 4 ),
	Variables( X( :age ), Y( :height ) ),
	Elements(
		Points( X, Y, Legend( 4 ), Summary Statistic( "Mean" ) ),
		Caption Box(
			X,
			Y,
			Legend( 5 ),
			Summary Statistic 2( "N" ),
			Location( "Graph per factor" )
Level XIII
Use a column to create the label - and use it as Shape Column
New Column( "label",
	Character,
	Formula(
		Char( Round( Col Mean( :height, :age ) ) ) || "
		Char( Col Number( :height, :age ) )
Graph Builder(
	Elements(
		Points(
			X,
			Y,
			Legend( 3 ),
			Set Shape Column( :label )
		Dispatch( {}, "400", ScaleBox,
			{Legend Model(
				4,
				Properties( 0, {Marker( "Circle" ), Marker Size( 30 )}, Item ID( "Mean", 1 ) )
Level XIII
you can stack different types of markers, like Bar/Float, Circle and marker with Marker shape:
N: inside the circle
mean: on the right
Learner_JMP
New Member
Thank you so much, hogi!
This is exactly how I envisioned!
You made my day!!!
