Ted
Ted
How to show a decimal digit (DO NOT round numbers on a histogram)?
How to show a decimal digit (DO NOT round numbers on a histogram)? Pls. look pic.
Re: How to show a decimal digit (DO NOT round numbers on a histogram)?
Right-click on the histogram.
Select Customize...
In the dialog box that appears, click on Histogram.
In the Percent Label Dec box, change the 0 to the number of decimal places you want displayed.
Dan Obermiller
Ted
Ted
Sorry, but look pic., pls
Anyway, Thanks Dan!
You must be using version 13 of JMP. The ability to change the decimal points was added in version 14 of JMP.
This is how it appears in v14:
and the final result:
Dan Obermiller
