qli107966
How to setup spec limit of each step for a process data with different steps
I have a set of process data with several variables with several steps. Does JMP have the capability to setup spec limit for each step? I was only able to find out the spec limit for the entire column, but no option for each step.
Thanks.
Re: How to setup spec limit of each step for a process data with different steps
JMP 18 and earlier does not allow for separate spec limits for different steps.  You will need to split out each step into a separate column and then apply the spec limits to each column.
     Tables=>Split
can be used to do the splitting.
qli107966
I see, thanks Txnelson for your prompt response.
May I ask which JMP version starts to have such capability?
Like Jim did say, this isn't currently possibly in JMP. Sometimes you might get by utilizing Process Screening platform which can do this or just utilizing graph builder but it depends on what you are trying to achieve.
Response removed
