How to setup spec limit of each step for a process data with different steps
Oct 18, 2024 11:24 PM(2616 views)
I have a set of process data with several variables with several steps. Does JMP have the capability to setup spec limit for each step? I was only able to find out the spec limit for the entire column, but no option for each step.
JMP 18 and earlier does not allow for separate spec limits for different steps. You will need to split out each step into a separate column and then apply the spec limits to each column.
Like Jim did say, this isn't currently possibly in JMP. Sometimes you might get by utilizing Process Screening platform which can do this or just utilizing graph builder but it depends on what you are trying to achieve.
