Fruit325
How to set the decimal point to 2 on all the flatforms?
Hi, how could we determine the decimal point shown on all the platforms? I am using the Fit Model platform and the quantified analysis (like the RMSE, R^2, etc.) is showing a lot of decimal points that may be unnecessary.
winfriedkoch0
Re: How to set the decimal point to 2 on all the flatforms?
I agree that 2 decimals is a reasonable choice in many scenarios.
W. Koch
I'm of no help.  I have to continually adjust the column width to change significant digits. Perhaps start here:
https://www.jmp.com/support/help/en/19.0/?os=mac&source=application#page/jmp/set-or-get-column-attri...
I think you might be able to utilize Semantic Format for this but I have never used it
https://www.jmp.com/support/help/en/18.0/#page/jmp/semantic-formatting.shtml
One way to do this at the Report level is to change the format for the outputs in your report and then save to a Platform Preset in JMP 18.
To set this up, go to the report, right click on the column values in a table and select: Format Column... and change to Fixed Decimal: 2. For example, the Summary of Fit report will look like this:
In JMP 18, you can now click the star icon in the top right of the report to save this as a Preset.
Now, whenever you run Fit Model, you can select the Preset you created and all the report customizations will be applied:
-Scott
Please see Platform Presets for more information.
