PS_Ato
How to set Link ID in a JSL script?
This was my guess:
:name("DOE ID")<<set property("Link ID", 1)
Re: How to set Link ID in a JSL script?
Good guess!
This will work, as long as the column has all unique values.
For documentation and example on this, see
     Help==>Scripting Index==>Data Table==>Column Scripting==>Set Property
PS_Ato
I tried again.
I've used the wrong "hierachie".
It works, when I use a new line.
Thanks
Good guess!
PS_Ato
This is what my guess was based on - but it did not work.
example:
:Weight << Set Property( "Units", lbs );
PS_Ato
I tried again.
Thanks
