rab2013
How to set Fit Y by X Group to Vertical Layout
I am struggling with scripting a Fit Y by X Group to display graphs vertically instead of horizontally.  Any suggestions?  Example script is below.  I am using JMP10.
Thanks!
bigClass = Open( "$SAMPLE_DATA/Big Class.JMP" );
one = bigClass << Oneway(
  Y( :height, :weight ),
  X( :age ),
// How can I change the Oneway layout to vertical?
(one << Report)[Outline Box( 1 )] << Horizontal( 0 );
Re: How to set Fit Y by X Group to Vertical Layout
You have the right idea but it is the top-most OutlineBox that controls the layout.  The following demonstrates how to access the parent OutlineBox to set the layout to vertical:
    (Report( one[1] ) << Parent)[Outline Box( 1 )] << SetHorizontal( 0 );
I hope that helps!
Wendy Murphrey
Wendy
I hope that helps!
Wendy Murphrey
Wendy
rab2013
Works great.  Thanks!
