Neo
Neo
How to send the second chart in a distribution by group to a journal using JSL?
Hi, I am back with another issue I am having with an example script.
dt = open("$SAMPLE_DATA/Big Class.jmp"); //loads data table
include ("plotScatterPlot.jsl"); // plots a 3D scatter plot
Window ("Big Class - Scatterplot 3D of age, height")[outlinebox(1)]<< journal;
include ("distributionBySex.jsl");
Window ("Big Class - Distribution")[outlinebox(1)]<< journal;
where where plotScatterPlot.jsl and distributionBySex.jsl respectively contain
Scatt3D = dt << Scatterplot 3D( Y( :age, :height ), X Axis( :age ), Y Axis( :height ) );
Names Default To Here (1);
Distribution(
	Stack( 1 ),
	Continuous Distribution(
		Column( :height ),
		Horizontal Layout( 1 ),
		Vertical( 0 )
	By( :sex )
which when run produce two chart windows called "Big Class - Scatterplot 3D of age" and "Big Class - Distribution" respectively.
Now, how to put the second chart of the distribution by sex into the journal already created above?
The line
only puts the top chart Distribution sex = F in the journal. I need to put the bottom chart Distribution sex = M in the existing journal. How to achieve this?
Thanks.
When it's too good to be true, it's neither
Re: How to send the second chart in a distribution by group to a journal using JSL?
  1. Please take the time to read the Scripting Guide found in the JMP Documentation Library available under the Help pull down menu.  There is a section that deals with the handling of Display Trees, which will help you with issues like the one you are having.
  2. You can use the following to upload to the journal the output from the Distribution Platform
    Window ("Big Class - Distribution")["Distributions sex=F"]<< journal;
    Window ("Big Class - Distribution")["Distributions sex=M"]<< journal;
