shuey
How to selectively evaluate variables in New Script() while preserving Expr() for deferred evaluation?
I'm creating a data table script using New Script() that needs to be evaluated later when a user clicks it. I need to substitute some variables at script-creation time (like a file path) while preserving Expr() calls that should only be evaluated when the script actually runs.
file_path = "C:\MyData\slopes.jmp";
dt << New Script("Plot Slopes",
    dt_slopes = Open( file_path );
    slope_array = dt_slopes:slope << Get Values;
    nw = New Window( "Slope Plots",
        gb = Graph Box()
    framebox = gb[Frame Box(1)];
    For Each( {slope}, slope_array,
        Eval( Eval Expr(
            framebox << Add Graphics Script(
                Y Function( Expr(slope) * x, x );
The problem: I need file_path to be evaluated and inserted as a literal string when creating the script, but the Expr(slope) inside the For Each loop must remain unevaluated until the script runs (when the user clicks it).
If I wrap everything in Eval(Eval Expr()) to substitute file_path, it also evaluates Expr(slope)prematurely, causing an error since slope doesn't exist yet.
What's the correct approach to selectively evaluate some variables while preserving others for deferred evaluation in stored data table scripts?
Re: How to selectively evaluate variables in New Script() while preserving Expr() for deferred evaluation?
One option is to add some Expr(Name Expr()) to your code
Eval(EvalExpr(
	dt << New Script(
		"Plot Slopes",
		dt_slopes = Open(Expr(file_path));
		nw = New Window("Slope Plots", gb = Graph Box());
		Expr(Name Expr(For Each({slope}, slope_array,
			Eval(Eval Expr(framebox << Add Graphics Script(Y Function(Expr(slope) * x, x))))
When you run only the EvalExpr part you will end up with following script
dt << New Script(
	"Plot Slopes",
	dt_slopes = Open("C:\MyData\slopes.jmp");
		Eval(
			Eval Expr(
Eval(EvalExpr(
	dt << New Script(
		"Plot Slopes",
dt << New Script(
	"Plot Slopes",
		Eval(
			Eval Expr(
Level XIII
nice trick:
expr(name expr())  as a synonym for  protect()
maybe vote here:
2 functions for the 2 meanings of expr()
