Stokes
How to select column from 1 to n
I am trying to select transpose column by the column number,
Considering there are too many column, is there a way to select from column(1) to column(n)
I am currently using below method which won't work when n>9999.
Thanks
Transpose(
columns(
Column( 3 ),
Column( 4 ),
Column( 9999 ))
Re: How to select column from 1 to n
First create list of strings with column names (many ways to do this, in the example I use transform Each and index) and then use Eval in Columns().
Something like this:
//setup example data
dt = Open("$SAMPLE_DATA/Blood Pressure.jmp");
Column(3) << Set Name("1");
Column(4) << Set Name("2");
Column(5) << Set Name("3");
Column(6) << Set Name("4");
Column(7) << Set Name("5");
col_list = Transform Each({num}, AsList(Index(1, 5)`), Char(num)); //JMP16
dt << Transpose(
	columns(Eval(col_list)),
	By(:Dose),
	Label(:Subject)
Here is my take on the issue, where you can just specift which column numbers you want to transform
dt = Open( "$SAMPLE_DATA/Blood Pressure.jmp" );
// add a complex col name to insure script can handle them
dt:bp 8m << set name( "BP+8M" );
// make table large
For( i = 1, i <= 11000, i++,
	dt << New Column( Column( dt, Mod( i, 9 ) + 3 ) << get name,
		set each value( As Column( dt, Mod( i, 9 ) + 3 ) )
// get rid of first 2 non useful columns
dt << delete columns( 1, 2 );
// get list of col names
colList = dt << get column names();
//set column numbers to be used
startColNum = 5;
endColNum = 10100;
// transform columns
transList = {};
For( i = startColNum , i <= endColNum, i++,
	Insert Into( transList, colList[i] )
dt << Transpose( columns( transList ) );
