XHLow
How to select column for Quantile Range Outlier using jsl
Hi JMP team,
I plan to do automated outlier analysis using Explore Outliers. The goal of this automation is to get a neat, easy to view table to show only row item and column item with outlier(This require to filter out those non-outlier column and row). Take Water Treatment as example below to rid row item without outlier.
dt = Open( "$SAMPLE_DATA/Water Treatment.jmp" );
obj = dt << Explore Outliers(
	Y( dt << Get Column Group( "Sensor Measurements" ) )
obj << Show only columns with outliers(1);
obj << Tail Quantile( 0.1 );
obj << Q(3);
obj << Quantile Range Outliers;
obj << ColorCells(dt << Get Column Group( "Sensor Measurements" ));
obj << SelectRows(dt << Get Column Group( "Sensor Measurements" ));
obj << ExcludeRows(dt << Get Column Group( "Sensor Measurements" ));
dt << select where( Excluded(Row State()) != 1 );
dt << Delete rows;
Question how to filter out non-outlier column using jsl code?
Regards,
XH Low
Re: How to select column for Quantile Range Outlier using jsl
The output of the Explore Outliers Platform in JMP 15, by default, only displays the columns that have outliers.  The script I provided assumed that all columns that were specified for analysis were displayed.  I have modified the code to force the displaying of all columns so that the "allEvaluatedList" gets properly populated.  I tested the code in JMP 15, and iit is now working.
obj = dt << Explore Outliers( Y( dt << Get Column Group( "Sensor Measurements" ) ) );
obj << Show only columns with outliers( 1 );
obj << Q( 3 );
obj << ColorCells( dt << Get Column Group( "Sensor Measurements" ) );
obj << SelectRows( dt << Get Column Group( "Sensor Measurements" ) );
obj << ExcludeRows( dt << Get Column Group( "Sensor Measurements" ) );
dt << select where( Excluded( Row State() ) != 1 );
dt << Delete rows;
obj << Show only columns with outliers( 0 );
allEvaluatedList = Report( obj )["Quantile Range Outliers", String Col Box( "Column" )] << get;
colList = Report( obj )["Quantile Range Outliers", String Col Box( "Column" )] << get;
For( i=1, i <= N Items(allEvaluatedList), i++, col=allEvaluatedList[i];
	If( Contains( colList, col ) == 0 ,
		dt << delete columns( col )
I have added a few lines of code at the bottom of your script, that deletes the columns that have no outliers.
obj << Q( 3 );
dt << Delete rows;
For Each( {col, i}, allEvaluatedList,
	If( Contains( colList, col ) == 0,
XHLow
Hi Jim,
Thanks for the code.
I tried the code above, my JMP15 did not support For Each(). I make some changes on For Each to For loop.
But still unable delete the non-outlier column.
obj << Q( 3 );
dt << Delete rows;
Non outlier column still present in the data table below.
Am I missing something?
obj << Q( 3 );
dt << Delete rows;
XHLow
Great!! It works now.
Thanks Jim.
