Knut
How to scale a graph to fit into a fixed size area
For patent filings, graphs need to fit into an 8H x 6.8W area, including all titles. How can I set up Graph Builder so that a graph fits into / fills a given area? (Setting the "frame" size does something else, but I couldn't find the definition of a "frame".)
Re: How to scale a graph to fit into a fixed size area
The units used in Frame Size, etc. are pixels.  I am not aware of the ability in JMP to set the graph size by inches.
Knut
Thanks Jim,
I can translate points into inches, that's not the problem, but which part of the graph is the "Frame"?
Knut
Craige_Hales
This will get you close. Your graph will be a bit smaller because of the window's title bar, which I believe is part of the window's size. Your dotsPerInch value might also be changed if you've set the scaling on your display. Retina displays and 4K displays will probably use larger DPI values.
DotsPerInch = 96; // typical for newer displays, 72 for older displays
report(gb)<<setwindowsize(6.8*DotsPerInch,8*DotsPerInch);
or...
The frame is the square box that the axes form.
Once you drag the window to the size you need, you can save the script and grab the size value from the script.
Setting graph builder's sizeSetting graph builder's size
That will not account for changing font sizes later however, since it is the frame size.
Craige
