How to save your charts,tables and other analysis in pdf and other formats?
I am trying to save the results using JMP Journal but I am unable to do so. Would anyone please help me out with this problem?
Peter_Bartell
Level VIII
Re: How to save your charts,tables and other analysis in pdf and other formats?
To add a bit to my colleague Ian's suggestion, if you are running JMP version 12, you can en masse export multiple platform report elements from the JMP analysis platform report window to your desired file format, select File -> Save As -> and then a desired file format. This will send all the major elements of the JMP report to that file format.
ian_jmp
Level X
Please find an example:
NamesDefaultToHere(1);
biv = dt << Bivariate(X(:height), Y(:Weight));
myJRN = biv << Journal;
myJRN << SavePDF("$DESKTOP/My Journal.pdf");
Thanks, it was helpful
Peter_Bartell
Level VIII
Thanks, it helped me out.
