utkcito
How to save a prediction formula with a different probability threshold?
is there a way to do this other than using the Model Classification Explorer Add-In? I am reviewing a few models and it is very time consuming. No matter what I do, either save formulas or predicted or publish, JMP is always using the default threshold it arrived to. I can play with the slider and see the results, but they don't translate to anything outside the report window. Unfortunately that is also the case for the prediction profiler, which I wanted to use with a different threshold.
Any insight into this would be greatly appreciated!
thanks,
uriel
dale_lehman
Re: How to save a prediction formula with a different probability threshold?
Usually the output of a classification model are the probabilities of the classifications.  These are not affected by the probability cutoff - the probability cutoff is applied to these probabilities to produce predicted classifications.  So, the prediction formula you really want is the formula that produces the probabilities.  Then it is a simple matter to produce the classifications from that.  If you want to do this in JMP and save that formula, just create a new formula column with IF (probability>x) then classification A, else classification B (something along those lines) and save that formula.  But the real formula that is of interest is the one that produces the probabilities.
pauldeen
An example piece of code that shows what you are doing and what you have so far would help us a lot to solve your issue
dale_lehman
