How to run/stop JSL scripts with Task Scheduler cleanly?
I have automated some extraction/analysis/export tasks of mine with a few JSL scripts and I have been trying to make use of Task Scheduler to run them on a fixed schedule.
I figured it would be easy enough, so I put the following into Task Scheduler. The script itself only takes about 10 seconds to run.
It doesn't seem to matter whether or not I put "//!" at the top of the script, it runs either way.
Program/script:
C:\...\jmp.exe
Add arguments (optional):
"C:\...\myScript.jsl"
It works when I ran the task manually but I can't seem to get it to stop, meaning that subsequent runs never end up running because the first is in a permanent state of:
"The task is currently running (0x41301)".
I tried making a simple batch file to do the same thing to run in Task Scheduler, but it arrives at the same result.
Batch File:
START "" C:\...\jmp.exe "C:\...\myScript.jsl"
Wondering if anyone has had any success with automating JSL scripts and has any pointers?
Thanks,
JP
msharp
Re: How to run/stop JSL scripts with Task Scheduler cleanly?
Just add the appropriate exit command at the end of your batch and jsl script.
batch it's simply 'exit' and jsl it's 'exit();'
msharp
Craige_Hales
The scripting index example for quit() is one of my favorites.  Save your work first.
Craige
