lwx228
Level VIII
How to run jsl script in excel VBA?
My JMP installation path is "c:\00\jmp\jmp.exe".
I need to start jMP.exe in a VBA and have "jMP.exe" run the "c:\abc.jsl" file.
I wrote VBA like this.The JMP program can be started, but JSL is not running.
Sub test()
    Shell "c:\00\jmp\jmp.exe ""c:\abc.jsl"""
End Sub
16 REPLIES 16
lwx228
Level VIII
Re: How to run jsl script in excel VBA?
I'm going to do it by default.
How should I set it up?
Thank Georg!
nascif_jmp
@lwx228 Also which OS and version of JMP you are using?
lwx228
Level VIII
win 7 64b
JMP pro 14.3
Thank nascif!
nascif_jmp
I can't reproduce the issue you are having on my environment. The exported .CSV looks fine.
I'd recommend trying out a newer version of JMP, or if you can't upgrade, reach out to tech support.
Looks like you are very close, though. :)
lwx228
Level VIII
This is also the case with CSV exported using JMP Pro version 15.1.
Thanks!
lwx228
Level VIII
Got it. It has to do with the default language choose.An error occurs when the column name is not in English.
nascif_jmp
Nice! Glad you found it.
