How to run JSL script in user opened JMP session instead creating a new seesion by JMP.dll?
Currently I developed a windows application based on Interop.JMP.dll. The application contains a functionality to generate JSL file and run it in JMP but I got a issue now. It seems can only create a new session and run it by application instead of using the session that user opened first. I'd like to confirm whether it's possible to run JSL in the session by user opened manually. Appreciate it if anyone can help with this problem. Thanks a lot.
0 REPLIES 0
