jb
jb
How to run JSL from within Visual Basic (VB)
Hello. I would like to run JSL from within VB.
I'm trying to combine a set of 2 character columns into a single character column "X", with each field separated by a space (" ").
In the JMP User Interface, I would select the 2 columns in the data table and then go to Cols > Utilities > Combine Columns.
Can anyone advise why the code below does not work?
I'm get the following error:
        Name Unresolved: jmp_dt in access or evaluation of 'jmp_dt' , jmp_dt/*###*/
Dim jmp_app As JMP.Application
Dim jmp_doc As JMP.Document
Dim jmp_dt  As JMP.DataTable
Dim str     As String
Set jmp_app = CreateObject("JMP.Application")
jmp_app.Visible = True
Set jmp_doc = jmp_app.OpenDocument("C:\Program Files\SAS\JMP\12\Samples\Data\Big Class.jmp")
Set jmp_dt = jmp_doc.GetDataTable
str = "Combine Columns( delimiter("" ""), Columns(:sex,:age), Column Name(""X"") );"
jmp_dt.JSLFunction (str)
jb
jb
Re: How to run JSL from within Visual Basic (VB)
From reading other JMP User Community threads, I learned about the Current Data Table function.
This function enables JSL to reference a table that is already open (in my case, it was opened by Visual Basic), and now my code works.
Here are my revised last 2 lines of code:
str = "dt = Current Data Table();" & _
      "dt << Combine Columns( Delimiter( "" "" ), Columns(:sex,:age), Column Name(""X"") );"
jmp_app.RunCommand str
Thanks to the JMP User Community for all the good information!
jb
jb
jb
jb
