samir
How to revere order in axis of graph builder in JSL ?
I am creating a heatmap with Graph builder.
I try to find a way to reverse the order of the axis by scripting but I cannot (although in the GUI, it is straight forward).
Please see script attached.
What I have so far is:
And I want it to be:
Thanks a lot.
ms
Super User ms
Re: How to revere order in axis of graph builder in JSL ?
Send the message directly to the Axisbox.
gb = Graph Builder(Variables(X(:Column), Y(:Row), Color(:Value)), Elements(Heatmap(X, Y, Legend(7))));
Report(gb)[Axisbox(1)] << {Min(0), Max(9), Inc(1)};
Report(gb)[Axisbox(2)] << {Min(0), Max(15), Inc(1), reversed scale};
ms
Super User ms
samir
Magic ! it works !
Do you know to which object I can send a message to change the gradient Label levels and properties ?
{Label Levels( [620 640 660 680 700 725 750 775 800] ),
Reverse Gradient( 1 )}
Thanks
heloiseheraud
Hi, you can do this:
gb<<SendToReport(
            Dispatch({},
                "400",
                ScaleBox,
                {Legend Model(
                      1,
                      Properties(
                          0,
                          {gradient(
                                          Reverse Gradient( 1 ) }
Cheers
ms
Super User ms
That seems to be more intricate. I would copy portions of the generated code from a manually designed graph.
This should work:
gb << Dispatch(
    "400",
    ScaleBox,
    {Legend Model(
        5,
        Properties(
            0,
            {gradient({Scale Values([620 640 660 680 700 725 750 775 800]), Reverse Labels(1)})}
samir
That's what I do so far, but it is not very elegant .
heloiseheraud
Well, to be consistent with the solution MS gave you about AxisBox, it should be something like:
Report(gb)[legend box(1)]<< {Label Levels( [620 640 660 680 700 725 750 775 800] ), Reverse Gradient( 1 ) }
but it doesn't work, and if you run
show properties(Report(gb)[legend box(1)])
you'll see that you have far less possibilities compared to
show properties(Report(gb)[axis box(1)])
Sorry I can't help more...
Article Labels
