HubP_SDe
How to retrieve tabulated values by script
Dear Community,
Based on the Tabulated output below, please how can I retrieve the amounts for categories 1, 2, 3 by script?
Based on another working script I`m currently there in my tries:
r = TabulateQuantiles << report;
tb_TabQuant = r[Table Box( 1 )];
tb_TabQuant << GetText;
QuantAmount1 = tb_TabQuant[2][1];
QuantAmount2 = tb_TabQuant[2][2];
QuantAmount3 = tb_TabQuant[2][2];
Show(QuantAmount1, QuantAmount2, QuantAmount3);
But getting following error:
Cannot subscript Display Box in access or evaluation of 'r[Table Box(1)]' , r[/*###*/Table Box( 1 )]
Thanks for your help!
Stéphane DELACROIX
Senior Simulation & Planning Engineer
HubP_SDe
Re: How to retrieve tabulated values by script
Thanks again Ian,
That is obviously the complex way, but it would be usefull in case I need to retrieve whole columns I suppose
I finally managed after finding the right syntax in the OnLine help page:
tb_TabQuant = TabulateQuantiles << MakeIntoDataTable(Invisible);
//tb_TabQuant << setName("Tabulation from "||(dt << getName));
QuantAmount1 = "24636";
QuantAmount2 = "1036";
QuantAmount3 = "257";
QuantAmount1 = tb_TabQuant[1,1];
QuantAmount2 = tb_TabQuant[1,2];
QuantAmount3 = tb_TabQuant[1,3];
The last blocking thing for my case wqs to convert these 3 values into stringsm which I managed using Char(number)
Cheers!
Have a great End of Year
Stéphane DELACROIX
ian_jmp
The best way to do something depends on what, precisely you need to do and how it fits into what you already have (and even then, 'best' is open to interpretation). But you might be able to use 'Summarize()', and dispense with 'Tabulate' altogether:
Summarize( exg = By( :age ), exm = Mean( :height ) );
Print(exg, exm);
ian_jmp
This will put the values into a new table:
NamesDefaultToHere(1);
tab =
dt << Tabulate(
	Add Table(
		Column Table( Grouping Columns( :age ) ),
		Row Table( Analysis Columns( :height ), Statistics( Mean ) )
Wait(2);
dt2 = tab << makeIntoDataTable;
dt2 << setName("Tabulation from "||(dt << getName));
HubP_SDe
Thanks a lot Ian,
The Tabulate Analysis does not behave like others thenm simply using [Table Box( i )] ...
Sorry, but i`m now struggling with retrieving the data from the data tablem and could not find it in the Scripting index:
Stéphane DELACROIX
ian_jmp
Yes, if you can avoid plucking values from the display tree that's usually a good strategy. If you want to get the values into variables, you can do something like this ('levels' will be a list, 'vals' a matrix):
tab =
dt << Tabulate(
	Add Table(
cols = dt2 << getColumnNames(:String);
RemoveFrom(cols, 1, 2);
dt3 = dt2 <<
Transpose(
	columns(Eval(cols)),
	Transpose selected rows only( 1 ),
	Label( :Statistics ),
	Output Table( (dt2 << getName) )
levels = Column(dt3, "Label") << getValues;
vals = Column(dt3, "Mean") << getValues;
Close(dt2, NoSave);
Close(dt3, NoSave);
HubP_SDe
Thanks again Ian,
Cheers!
Stéphane DELACROIX
ian_jmp
Print(exg, exm);
HubP_SDe
Great suggestion Ian,
Would indeed make my life easier for this specific purpose!
Stéphane DELACROIX
