vharibal
How to retrieve misclassification rate value from report
I am looking to save misclassification rate value after running Generalized Regression Lasso into a data table. Could someone please assist?
Its shown in red in the image below.
Re: How to retrieve misclassification rate value from report
One option is to open Properties menu (toolbar) and then check the report path under Box Path
You can then use that in a script
dt = Open("$SAMPLE_DATA/Penicillin.jmp");
fm = dt << Fit Model(
	Freq(:Count),
	Y(:Response),
	Effects(:"ln(dose)"n),
	Personality("Generalized Regression"),
	Generalized Distribution("Binomial"),
	Run(
		Fit(
			Estimation Method(Logistic Regression),
			Validation Method(None),
			Confusion Matrix(0.5)
fm << Confusion Matrix(1);
ncb = Report(fm)["Logistic Regression","Confusion Matrix","Training",NumberColBox("Misclassification Rate")];
rate = (ncb << get)[1];
	Freq(:Count),
	Y(:Response),
	Run(
		Fit(
vharibal
Great!!  this works
Thank you very much
Victor_G
Hi @vharibal,
If you right-click on the value of interest and then choose "Make into Data Table" or "Make Combined Data Table" (if you have several models for several responses and you want the missclassification rates for all responses saved in the same table), you can extract the values you're interested in in a new JMP table file. Reformat Tables in JMP Reports
EDIT: Curiously, this option is not available for the missclassification rates and confusion matrices.
Hope this answer will help you,
Victor GUILLER
One of the great standard features of JMP is that one can right click on any display table and select "Make into a Data Table"
