simonmfelix
How to resize graphs in Graph Builder in JMP10?
Hello everyone, I've recently upgraded to JMP10 and to my dismay i was unable to change the graph size in Graph Builder. This was easy to do in JMP9  - simply drag the edges of the chart outline to change the size of the graph. However in JMP10, neither dragging nor right clicking inside the graph (Graph --> Size/Scale) no longer works. Is this a bug in JMP 10 or is there something wrong with my installation?
Regards,
Simon
mpb
mpb
Re: How to resize graphs in Graph Builder in JMP10?
From the fitness data I used the graph builder to create a simple Oxy versus Runtime plot and was able to resize the resulting plot. I'm running JMP 10 32 bit under Win7 64 bit.
simonmfelix
Hi mpb,
Thanks for the reply, I'm actually using JMP 64 bit in a Win7 64 bit. I noticed that the problem went away after i installed the latest update JMP 10.0.1 update. Now I'm able to resize my graph builder graphs again.
Regards,
Simon
