lazzybug
How to replace :column_name with variable in JMP JSL?
@jthiCan you help me to fix the code error below? How to use variable to replace :column name in the correct way? Thank you so much for your help.
Open( "$SAMPLE_DATA/Big Class.jmp" );
hvar = "height";
gvar = "sex";
std = Col Std Dev( if(Excluded( Row State() ) == 0 & column(gvar) =="M", column(hvar) ));
//std = Col Std Dev( if(Excluded( Row State() ) == 0 & :sex =="M", column(hvar) ));
show(std);
pmroz
Re: How to replace :column_name with variable in JMP JSL?
hvar = "height";
gvar = "sex";
std = Col Std Dev( if(!Excluded( Row State() ) & as column(dt, gvar) == "M", as column(dt, hvar) ));
show(std);
Sometimes you need to use "as column".  Sometimes just "column".
How you replace it depends on the use case, in your case using AsColumn as @pmroz suggested is the easiest option.
Few links
Below are few other options but they do require more scripting which is usually unnecessary in this type of cases
hvar = "height";
gvar = "sex";
// As Column
std = Col Std Dev(If(!Excluded(Row State()) & As Column(dt, gvar) == "M", As Column(dt, hvar)));
// Data table subscripting
// https://community.jmp.com/t5/Uncharted/Data-table-subscripting/ba-p/21013
rows_of_interest = dt << Get Rows Where(Excluded(Row State()) == 0 & Column(gvar)[] == "M");
std2 = Std Dev(dt[rows_of_interest, hvar]);
// Build and evaluate expression
// https://community.jmp.com/t5/JSL-Cookbook-Archived/Insert-one-expression-into-another-using-Eval-Insert-Eval-Expr/ta-p/48998
std3 = Eval(Substitute(
	Expr(Col Std Dev(If(!Excluded(Row State()) & groupcol == "M", numcol))),
	Expr(groupcol), Name Expr(AsColumn(gvar)),
	Expr(numcol), Name Expr(AsColumn(hvar))
// Check
std4 = Col Std Dev(If(Excluded(Row State()) == 0 & :sex == "M", :height));
show(std, std2, std3, std4);
pmroz
hvar = "height";
gvar = "sex";
show(std);
lazzybug
Thank you so much. This works very well.
Few links
hvar = "height";
gvar = "sex";
// As Column
// Check
