AJ
AJ
How to rename the default graph builder script in a data table ?
Below code generates a script for graph builder and is saved under the data table.
obj = Graph Builder(
	Variables( X( :Sex ), Y( :Height ), Group X( :Age ) ),
	Elements( Box Plot( X, Y ) )
obj << Save Script to Data Table;
The names of the graph builder objects are using the default naming pattern for this platform. How do I rename them to my choice? (I have attached a screen shot and the graph builder names are highlighted in yellow)
I have tried using "set name" before and after saving the script to the data table but it didn't work.
Thanks in advance!
AJ
David_Burnham
Re: How to rename the default graph builder script in a data table ?
It looks like the ability to add the name as an argument is a version 13 feature.
Here is a workaround:
obj << Save Script To Data Table;
lstNames = dt << Get Table Script Names;
dt << Rename Table Script( lstNames[NItems(lstNames)], "My Script" );
-Dave
AJ
AJ
Thanks a lot for your effort! This works perfect for me.
David_Burnham
Here's a couple of approaches.
First method, based directly on your code.  Just add an argument to the message:
obj << Save Script to Data Table("My Script");
The second method, if you simply want to attacth the script with a name, but not execute it:
dt << Set Property("My Script,",
	Graph Builder(
-Dave
AJ
AJ
Dave,
  Thanks for your response. I need to execute the script generated from graph builder and hence I tried  option 1.
Unfortunately, it still saves the script by the name "Graph builder" and not "My script".  For your information, I am using JMP 12.
David_Burnham
-Dave
AJ
AJ
